      0KCF-08U
      Prohibiting PC Faxing (imageRUNNER 1435iF Only)
      You can prohibit users from PC faxing (faxing from a computer).
      1
      Press .
      2
      Use / to select <System Management Settings>, and press .
      If the logon screen appears, enter the correct ID and PIN using the numeric keys, and then press . Logging on to the Machine
      3
      Select <Restrict TX Function>  <Allow Fax Driver TX>.
      4
      Select <Off>, and press .
       <Off>
      Disables PC faxing.
       <On>
      Enables PC faxing.
      5
      Press .
