[TCP/IP Settings].
1
Click [Security Settings]
[Remote UI Settings].![]() |
2
Click [Edit...].
3
Select the [Use TLS] check box and click [OK].
Using the operation panel
You can enable or disable the TLS encrypted communication from
. Use TLSStarting the Remote UI with TLS
If you try to start the Remote UI when TLS is enabled, a security alert may be displayed regarding the security certificate. In this case, check that the correct URL is entered in the address field, and then proceed to display the Remote UI screen. Starting the Remote UI
Enabling TLS for e-mailing (imageRUNNER 1435iF / 1435i Only)
If the SMTP server and the POP3 server support TLS, you can enable TLS for communication with these servers (Configuring E-mail Settings). For more information about the SMTP server and the POP3 server, contact your Internet service provider or Network Administrator.
