Two-Sided Printing
This mode enables you to print two successive pages of a stored file, on both sides of a sheet of paper.
Press (Main Menu) → [Access Stored Files].
Select the desired Mail Box → select the desired file → press [Print].
Press [Change Print Settings].
4.
Press [2-Sided Printing].
To change the paper source, see "Paper Selection."
5.
Select the type of finishing → press [OK].
[Book Type]:
The front and back sides of the print will have the same top-bottom orientation.
[Calendar Type]:
The front and back sides of the print will have the opposite top-bottom orientation.
If you want to print the first page of each file on the front when files are merged and the Finishing mode is selected (except for [Group (Same Pages)]), press [Print 1st Page on Front].
If you want to print continuously without inserting any blank pages between the files, press [Always Print 2-Sided].
6.
Press [Start Printing].
You may not be able to print, depending on the paper type.
Paper used to make two-sided prints must conform to the following specifications:
Paper size: 13" x 19", 12" x 18", 12 5/8" x 17 11/16", 11" x 17", LGL, LTR, LTRR, EXEC, and Custom Size (5 1/2" x 7 1/8" to 13" x 19 1/4" (139.7 mm x 182 mm to 330.2 mm x 487.7 mm)), except for transparencies, clear film, labels, or tab paper
Paper weight: 16 lb bond to 110 lb cover (60 to 300 g/m2)
If there are an odd number of pages in the file, the back side of the last print is left blank. (The machine's counter does not count the blank page as a print.)
» Access Stored Files » Two-Sided Printing
0S9Y-0SX
