Finishing Size
Main Document Size
Cover Page Size
COM
(178 mm x 229 mm) |
LTR
(216 mm x 279 mm) |
11" x 17"
(279 mm x 432 mm) |
B5
(182 mm x 257 mm) |
A4
(210 mm x 297 mm) |
A3
(297 mm x 420 mm) |
A4
(210 mm x 297 mm) |
226 mm x 310 mm
SRA3
(320 mm x 450 mm) |
LTR
(216 mm x 279 mm) |
9" x 12"
(229 mm x 305 mm) |
13" x 19"
(330 mm x 482 mm) |
Trimming Setting
X (Horizontal)
Y (Vertical)
Do Not Trim
7 1/8" to 8 1/2"
(182.0 mm to 216.0 mm)
10 1/8" to 11 3/4"
(257.0 mm to 297.0 mm)
Specify by Finishing Size
Vertical
Trim |
5 1/2" to 8 1/2"
(138.0 mm to 216.0 mm)
10 1/8" to 11 3/4"
3-Way Trim
5 1/2" to 8 1/2"
8" to 11 3/4"
(203.0 mm to 297.0 mm)
Specify by Trim Width
Vertical
Trim |
1/4" to 2"
(6.5 mm to 49.5 mm)
3-Way Trim
1/4" to 2"
(6.5 mm to 49.5 mm)
1/4" to 1 5/8"
(6.5 mm to 39.5 mm)
Paper
Maximum Number of
Sheets |
Minimum Number of
Sheets |
16 lb bond (60 g/m2 to 63 g/m2)
200
30
17 lb bond to 20 lb bond (64 g/m2 to 79 g/m2)
200
10
20 lb bond to 28 lb bond
(80 g/m2 to 105 g/m2)
150
10
29 lb bond to 60 lb cover
(106 g/m2 to 163 g/m2)
10 (as sheet insertions)
Paper Source
Paper Weight
Main Unit
24 lb bond to 110 lb cover
(90 g/m2 to 300 g/m2)
Document Insertion Unit-N1
Trimming Setting
X (Horizontal)
Y (Vertical)
Do Not Trim
Width of the Finishing Size
(7 1/8" to 8 1/2" (182.0 mm to 216.0 mm)) |
(10 1/8" to 11 3/4" (257.0 mm to 297.0 mm)) |
Vertical
Trim |
Width of the Finishing Size + 1/4" to 2" (6.5 mm to 49.5 mm)
(7 1/8" to 9" (182.0 mm to 228.6 mm)) |
3-Way
Trim |
Width of the Finishing Size + 1/2" to 3 1/8" (13.0 mm to 79.0 mm)
(10 1/8" to 12 5/8" (257.0 mm to 320.0 mm)) |
Trimming Setting
X (Horizontal)
Y (Vertical)
Do Not Trim
14 3/8" (364.0 mm) to Twice the Size of the Main Document + 1 1/4" (30.5 mm)
(14 3/8" to 18 1/4" (364.0 mm to 462.5 mm)) |
Size |
Vertical
Trim |
(14 3/8" to 19 1/4" (364.0 mm to 487.7 mm)) |
Size |
3-Way
Trim |
(10 1/8" to 13" (257.0 mm to 330.2 mm)) |
The Perfect Binding mode can be set only if the Perfect Binder-E1 is attached.
The Booklet mode and the Perfect Binding mode cannot be set if multiple documents in different resolution are selected in [Merge Files and Print].
If the thickness of a booklet bound using the Perfect Binding mode exceeds 1" (25 mm), a paper jam may occur.
Be sure to correctly set the paper type. When printing on special types of paper, such as heavy paper, be sure to correctly set the paper type, especially if you are using heavy paper. If the type of paper is not set correctly, it could adversely affect the quality of the image. Moreover, the fixing unit may become dirty and require a service repair, or the paper could jam.
Before performing perfect binding, we recommend you to check the curl state of a using paper type. You need to print out the main document and a cover to the finisher or stacker, and check that curl is within the following specified value.
![]() *1 Height of Curl: Less than + 3/8" (10 mm)
*2 Height of Curl: Less than - 3/8" (10 mm)
*3 Length of Curl: More than 1 15/16" (50 mm)
If you use the paper type that curls easily exceeding the specified value for perfect binding, the following problems may occur:
The finishing size of output is different from the specified one.
Paper jam occurs.
Error occurs.
Binding quality deteriorates. (For example, glue is not applied correctly and sheets come off.)
The stacking limit of the optional Perfect Binder-E1 is 1000 sheets, or 5" (127 mm) in height of paper stack. If the paper stack exceeds the limit, printing stops temporarily. Printing resumes when the output in the stacker is removed.
Gluing becomes possible about 440 seconds after the internal heater of the optional Perfect Binder-E1 is turned on.
(Main Menu) → [Access Stored Files].
If you are using paper from 20 lb bond to 28 lb bond (80 g/m2 to 105 g/m2) for the main document and the output is more than 150 sheets, the booklet may not be made because of its thickness. In this case, a paper jam may occur. Reduce the number of pages in the main document.
Be sure to correctly set the paper type. If the type of paper is not set correctly, the job may be canceled.
Be sure to correctly set the finishing size. If the size of the cover matches either of the following conditions, a paper jam may occur.
Trimmed:Trimming width of the fore edge of the cover is more than 2" (50 mm).
Not Trimmed: Length of the finishing size exceeds the width of the stacker (about 11 3/4" (297 mm)), or the depth of the finishing size exceeds the height of the stacker (about 8 3/4" (221 mm)).
If you want to register and edit the configured finishing size, press [Reg.].
You must select the same paper size for the flyleaf as that used for the main document.
If you load preprinted paper to use as the flyleaf into the document insertion unit, you must load the paper face up.
When using the Saddle Finisher-AN2, use the paper shown below.
Main document: 16 lb bond to 110 lb cover (60 to 300 g/m2)
Flyleaf: More than the paper thickness of main document, and 16 lb bond to 110 lb cover (60 to 300 g/m2)
If you set a different paper size for the front flyleaf, back flyleaf, or insert sheets, the paper sizes for the other features are automatically changed to the new paper size. However, changing the paper source for a feature to a source with the same paper size does not change the settings for the other features.
Before feeding paper from the Document Insertion Unit-N1, load paper into the Document Insertion Unit-N1 and specify the paper size.
To feed paper from the Document Insertion Unit-N1, select [Sheet Inserter 1] or [Sheet Inserter 2]. If paper is being fed from the Document Insertion Unit-N1 for the current job, press [Change Insert. 1 Ppr.] or [Change Insert. 2 Ppr.] to select paper for the sheet insertions.
You can insert a total of up to 100 sheet insertions.
[Left Opening]:
A booklet that opens to the left is created.
[Right Opening]:
A booklet that opens to the right is created.
To place paper for the cover page in the optional Document Insertion Unit-N1, load the paper as shown in the illustration below:
* Feeding Direction to the Sheet Inserter
For instructions on loading paper into the Document Insertion Unit-N1, see "Loading Paper into the Document Insertion Unit-N1 (Optional)."
If you enter a value other than 0, you can switch between the positive and negative adjustment amount by pressing [±].
If the amount of the trimming is between 1/4" to 2" (6.0 mm to 50.0 mm), each setting can be applied.
Cover Paper that is fed from the optional Document Insertion Unit-N1 cannot be printed on.
