0S9Y-00U
All the elements you will ever need in a color digital multitasking machine.
This machine incorporates a rich array of input and output features that can greatly enhance your efficiency. Equipped with features that meet the needs of document work, the machine represents the ultimate in color digital multitasking machines.
* Indicates functions, which require an optional product(s).
For information on the optional products required to use each function, see
"Optional Products Required for Each Function."
You can use this machine as a high-speed network printer. Various outputs are also possible, such as 2-sided printing and page alignment.
You can use this machine as the postscript printer with the Adobe PostScript3 software. For details, see the manual provided with the imagePRESS Server.
In addition to normal copying functions, convenient new functions, such as "Copy Sample" which helps to avoid copy errors, "Booklet" for making copies into booklets, and "Different Size Originals" for copying originals of different sizes together in one copy operation, are provided to increase your productivity.
The Scan and Store function enables you to save document data that has been scanned from the scanner unit or created on a computer. The saved data can be printed at a specified time, or merged with separately saved data or data created on a computer for simultaneous processing.
The Send function enables you to send scanned image or document data to file servers, or send it by e-mail or I-fax. A variety of file formats are supported (JPEG, TIFF, PDF, XPS, OOXML), which offer you greater flexibility in accommodating digital workplace environments.
If the Universal Send Advanced Feature Set is activated, you can add Office Open XML (pptx/docx) to the list of supported file formats.
You can control functions, such as confirming the status of the machine, job operations, and printing instructions for saved scanned data, all from your computer's Web browser.
The Network Scan function enables you to use this machine as a conventional scanner. You can scan a document using the machine, and read the data in an application you are using on your computer. You can scan images of up to A3 in size at a resolution of 600 x 600 dpi.
You can specify various settings of the machine connected to a network when using utility software. You can specify initial settings, confirm the status of the machine, and manage documents.
