e-ManualTopSite mapHelp
Top » Basic Operations » The Touch Panel Display » Adjusting the Position and Angle of the Touch Panel Display
0S9Y-013
You can adjust the position and angle of the control panel. Adjust the position and angle of the control panel if the touch panel display cannot be seen clearly.
Hold the control panel with both hands, as shown below.
Slowly adjust the angle of the control panel.
You can adjust the angle, as indicated below. If you exceed the adjustment range in any direction, you could break the arm that supports the control panel.
