You can print various types of reports from the machine, to check settings and logs. Some reports are printed automatically, and some are printed manually. You can also set to print some reports automatically only when an error occurs.
You can print the following types of reports from the machine.
The Counter Report contains the number of pages copied/printed and the number of completed send jobs.
The Page Count List contains the Copy, Scan, and Printer counter information for each department.
The Print Log List contains the print job history.
The Device Information Delivery Destination List contains information about registered delivery destinations.
This report is a list which enables you to check the send, receive, and access logs for device information.
This report is used to check a list of jobs before sending or after sending.
This report is used to check whether documents were sent correctly to their intended destinations.
This report is a list which enables you to check the results of all sending and receiving.
You can print the contents of the forwarding settings that have been specified.
You can print the registered LDAP server settings.
This report enables you to print and check the contents of the Address List (Address Lists 1 to 10 or one-touch buttons) in [Management Settings] (Settings/Registration).
You can print the history of file storage.
Prints the registration information for Settings/Registration. This is useful for checking settings details.
You can print the information for the files stored in a mail box.
The following conditions must be met for a report to be printed: There is a paper deck with [Other] in [Paper Drawer Auto Selection On/Off] in [Function Settings] (Settings/Registration) set to 'On'.
One of the following paper sizes is loaded in that paper deck:
11" x 17"
LGL
LTR
LTRR
STMTR
The loaded paper is one of the following types:
Plain
Recycled
Color
Coated
Custom Paper Type (paper with the following settings; Basis Weight: 17 lb bond to 28 lb bond (64 g/m2 to 105 g/m2), Type: Normal, Finish: Uncoated or Recycled)
However, if [Consider Paper Type] for Copy is set to 'On' in [Paper Drawer Auto Selection On/Off] in [Function Settings] (Settings/Registration), paper is not fed from paper drawers with color paper specified.
