e-ManualTopSite mapHelp
Top » Basic Operations » The Touch Panel Display » Shortcut to Settings/Registration
0S9Y-00Y
You can register shortcuts for frequently used Settings/Registration settings in [Settings/Reg.Shortcut]. By using the shortcut, you can display the settings screen directly.
The [Settings/Reg.Shortcut] button can be displayed on the top of the screen or on the Main Menu screen. For more information, see "Setting the Main Menu Screen."
To perform the procedure described in this section, you must log in to the machine as an administrator. (See "Logging In to the Machine as an Administrator.")
Press [Settings/Reg.Shortcut].
Press [Register].
Select the button in which you want to register settings.
You can select the assigned button to change the registered settings.
4.
Select the Settings/Registration settings to be registered → press [OK].
If you do not want to register settings, select [Unassigned].
5.
Press [Close].
