(Energy Saver), or specify to have the machine enter the Sleep mode at a preset time. To reactivate the machine, press
(Energy Saver) again.
(Energy Saver) on the control panel. To reactivate the machine, press
(Energy Saver) again.|
The Energy Saver mode's energy conservation level can be set to '-10 %', '-25 %', '-50 %', or 'Zero Restore Time'. The default setting is '-10 %'. (See "Changing the Energy Saver Mode.")
(Energy Saver).|
Even if the main power switch is turned OFF, a small amount of energy is consumed if the power plug is left inserted into the power outlet. If you do not want any energy consumed, remove the power plug from the power outlet.
For more information on the mode which activates after
(Energy Saver) is pressed, see "Switching Modes Activated After Pressing Energy Saver Key."The touch panel display turns OFF when the machine enters the Sleep mode.
The machine can continue to receive I-fax documents, and process or print data sent from computers even if it is in the Sleep mode.
The machine may not enter the Sleep mode completely, depending on certain conditions. For more information, see "Energy Consumption in the Sleep Mode."
Press [Energy Saver] after pressing
(Energy Saver) to enter the Sleep mode when not using the machine for a prolonged period of time, for example, at night.The time it takes for the machine to automatically enter the Sleep mode can be set from 5 minutes to 4 hours. The default setting is '15' minutes. (See "Auto Sleep Time.")
The Auto Sleep Weekly Timer settings can be set from Sunday to Saturday and 00:00 to 23:59. (See "Auto Sleep Weekly Timer Settings.")
If you select [Low] for [Sleep Mode Energy Use], it may take approximately 10 seconds for the touch panel display to appear after pressing
(Energy Saver). (See "Energy Consumption in the Sleep Mode.") |
