Various system options can be installed in the machine.
You can install system options in the machine using the Register/Update Software function.
Installing system options enables you to use new customizable functions for the machine. You can also uninstall these applications.
The system options you can install in this machine are as follows:
Data Erase Kit
Color Universal Send Kit
Universal Send Advanced Feature Set
Universal Send Security Feature Set
Installing System Options Applications
The procedure for installing system options applications in the machine differs depending on whether installation is performed with the machine connected or not connected to an external network. Refer to the following to select the appropriate method:
To perform installation with the machine connected to an external network:
Access a delivery server from the machine, and install the system option application.
To perform installation with the machine not connected to an external network:
Use the license file/license key obtained from the License Management System to install the system option.
License registration may be required, depending on the system option.
Depending on the installed system option, you can download the manual or related software for the system option from the following URL. http://canon.com/fau/downloads
When downloading manuals and related software for system options, prepare the license access number certificate that was included in the package. If there is no manual to download, see the description of the function in this manual.
Multiple users cannot use the "Register/Update Software" at the same time.
