Output Paper
[On], [Inserter 1], or [Inserter 2]
The gray sheets: Paper placed in the inserter
Nothing will be printed on the paper used for the cover.
You cannot use this function in combination with 'Transparency Interleaving'.
This function cannot be used if the 'Finishing' is set to [Off], [Collate], [Offset+Group], or [Staple+Group].
This function is available for selection if the Document Insertion Unit-H1, Document Insertion Unit-J1, or Document Insertion/Folding Unit-G1 is attached.
You can place the following paper sizes and types in the Document Insertion Unit-H1:
Paper sizes: 13” x 19” , 12 5/8” x 17 11/16”, 12” x 18”, 11” x 17”, LGL, LTR, LTRR, EXEC
Paper types: Thin, Plain Paper, Heavy, Recycled, Color Paper, Pre-punched, Letterhead, Bond Paper, Tab Paper, Labels, Coated, Texture Paper, or Vellum Paper
You can place the following paper sizes and types in the Document Insertion Unit-J1 or Document Insertion/Folding Unit-G1:
Paper types: Thin, Plain Paper, Heavy, Recycled, Color Paper, Letterhead, Bond Paper, Tab Paper, Labels, Coated, Texture Paper, or Vellum Paper
