Scaling Documents
You can enlarge or reduce documents to match the output paper size.
There are two methods for scaling a document: select the output size of the document to scale it automatically, or specify the scaling value manually.
Click [Page Setup].
For instructions on how to display the printer driver screen, see "Printing" or "Configuring the Default Print Settings."
Select page size of the document you created in the application from [Page Size].
Select output size of the document from [Output Size].
The document is scaled automatically according to the settings made in [Page Size] and [Output Size].
4.
If you want to increase or decrease the magnification manually, select [Manual Scaling] → specify the scaling ratio for [Scaling].
5.
Click [OK].
Depending on the selected page size and printer model you are using, you may not be able to magnify the document.
Depending on the printer model you are using, you may not be able to magnify the document to the optimum ratio for the selected page size.
The display may vary according to the operating system, as well as the type and version of the printer driver.
» Print » Printing from a Computer (Windows) » Scaling Documents
08JK-1HW
