[ICC Profile]*, [D. Link Profile]
This setting enables you to select whether to use the ICC Profile or the Device Link Profile for the RGB input data.
The machine compensates for the difference between the color spaces used for the input profile (applied to the color space used for input data) and the output profile (defines device dependent color space).
You can directly convert the input color space to the output color space.
You can select whether to use the ICC Profile or the Device Link Profile for the CMYK input data.
If the color mode is set to [Black & White], the device link profile setting is invalid.
