If the machine receives data with a device independent (CIE based) color space definition, it is color processed with the specified settings. Therefore, 'RGB Source Profile' is not applied by the machine.
You can also download the profile from imageWARE Enterprise Management Console.
Device independent colors are not dependent on any particular device, such as a monitor, and are meant to be true representations of colors as perceived by the human eye. These color representations, called device independent color spaces, result from work carried out by the Commission Internationale d'Eclairage (CIE) and for that reason are also called CIE based color spaces.
If a profile with the name of "None" is downloaded to the machine, the profile is not applied and the [None] setting on the menu is applied.
