Two-sided printing can use either the paper drawer or the multi-purpose tray with the following sizes.
13" x 19", 12 5/8" x 17 11/16", 12" x 18", 11" x 17", LGL, LTR, LTRR, EXEC, STMTR, A3, A4, A4R, A5R, B4, B5, B5R, and Custom Size (5 1/2" x 7 1/8" to 13" x 19 1/4" (139.7 mm x 182 mm to 330.2 mm x 487.7 mm))
Two-sided printing can use paper within the following range:
14 lb bond to 80 lb cover (52 g/m2 to 220 g/m2)
When printing on letterhead paper, or paper with a logo (such as a cover sheet), please note the following:
If the paper is fed from a paper drawer, the printing surface should be face down.
If the paper is fed from the multi-purpose tray or the paper deck, the printing surface should be face up.
If you use paper less than 16 lb bond (60 g/m2) in weight for two-sided printing when a finisher is attached, the output paper may not be aligned.
