[Normal]*, [Photo], [TR Normal], [TR Photo], [Download Profile]
This setting allows you to define the profile that is appropriate for the data you are going to print. It is applied to all data in the print job, so make sure the selected profile is right for your job.
Settings can be applied separately for text, graphics, and image data.
Under most circumstances, it is preferable to select [Normal] for text and graphics data, and [Photo] for image data.
This setting prints the colors closely matching the ones displayed on your monitor.
This setting prints colors close to photographic prints.
This setting prints the colors closely matching the ones displayed on your monitor, and also reduces toner bleeding of text and fine lines.
This setting prints colors close to photographic prints, and also reduces toner bleeding of text and fine lines.
You can store up to 100 profiles.
You can also download the profile from imageWARE Enterprise Management Console.
Selecting [Photo] or [TR Normal] in the 'Output Profile' and [Saturation] in the 'Matching Method' is equivalent to setting 'Matching Method' to [VIVID Photo] in the printer driver.
If [None] is selected for "RGB Source Profile" or "CMYK Simulation Profile" and the machine receives a device dependent color space definition that is color processed by the host computer, this setting is not applied.
