This function is available for selection if the External 2/3 Hole Puncher-A1 is attached to the Staple Finisher-K1/Staple Finisher-L1 or Booklet Finisher-K1/Booklet Finisher-L1.
The machine automatically selects how many holes to punch, depending on the selected paper size:
When the External 2/3 Hole Puncher-A1 is attached to the Staple Finisher-K1 or Booklet Finisher-K1
Two holes: LGL, LTRR
Three holes: 11" x 17", LTR, A3, A4, EXEC
When the External 2/3 Hole Puncher-A1 is attached to the Staple Finisher-L1 or Booklet Finisher-L1
Make sure to select compatible settings when using Staple and Punch simultaneously. If conflicting settings are selected, such as the staple setting for the right side of the paper and the punch setting for the left, the machine will use neither Staple nor Punch.
Holes can only be punched in Thin Paper, Plain Paper, Heavy Paper, Letterhead, Recycled Paper, Color Paper, Coated Paper, Tab Paper, and Bond Paper.
