[None]*, [PS], [PCL], [XPS], [PDF]
This setting determines which personality should be used if a job is received without a specified command language or Direct Print data. The Mode Priority mode is used when you set [Personality] to [Auto].
This does not specify a preferred personality. If a job is received without a specified command language or Direct Print data, the current personality is used. The default setting is [None].
This assigns priority to the PS personality.
This assigns priority to the PCL personality.
This assigns priority to the XPS mode.
This assigns priority to the PDF mode.
This mode is not available when printing in the UFR II mode.
