[ICC Profile]*, [Gamma], [Kyuanos (Color)]
This setting enables you to set the type of color matching method to apply for each text, graphics, and image that make the print job, or for each color space, such as RGB and CMYK.
You can select the matching method to compensate the difference between the color spaces used for the input profile (applied to the color space used for input data) and the output profile (defines device dependent color space).
You can adjust the brightness of printing not to lose the brightest and darkest portions of the original data. Set this mode if you want to adjust the brightness, for instance when the printout is brighter than the original image on a monitor.
You can select the type of the ambient light used on the printed documents in the space displayed on the monitor that matches the printed document.
If the 'color mode' is set to [Black & White], the ICC profile settings are applied even though [Kyuanos (Color)] is selected.
