Kyuanos Set. (Color Only)
[sRGB]*, [Adobe RGB]
This setting enables you to match the prints to the monitor display (sRGB or Adobe RGB).
Color matching is performed to match prints to an sRGB compatible monitor.
Color matching is performed to match prints to an Adobe RGB compatible monitor.
[D50]*, [D65]
This setting enables you to specify the high color rendering setting to perform color matching for each print job.
Ambient light compensation is performed to match high color temperature of 5,000 K.
Ambient light compensation is performed to match high color temperature of 6,500 K.
If the 'Color Mode' is set to [Black & White], the setting for [Monitor Color Space] is invalid.
The Monitor Color Space or Environment Light mode is valid only when [Kyuanos (Color)] is selected in the Matching Mode setting.
