08JK-1RX
[Yes], [No]*
This setting enables you to specify whether to append a carriage return (CR) when line feed code (LF) is received.
The print head moves to the beginning of the next line when line feed code is received.
The print head moves down to the next line when line feed code is received, and the margin does not change (such as to the beginning of the next line).
