Top » Problem Solving » Clearing Staple Jams (For Optional Products) » Stapler Unit of the Staple Finisher-Q1 PRO/Booklet Finisher-Q1 PRO
08KE-0KS
Check the location of the staple jam, and follow the procedure described below, and the procedure that appears on the touch panel display, to remove any jammed staples.
Take care when handling the optional equipment that is attached to the machine. When an optional unit's cover is opened to replace a staple cartridge, discard the punch waste, discard the trim waste, discard the staple waste, or clear paper or staple jams, prints may still be output if other optional units are operating normally, and are not involved in the paper or staple jam removal procedure.
The Staple Finisher-Q1 PRO and Booklet Finisher-Q1 PRO are optional products.
Open the front cover of the finisher.
Remove the paper waiting to be stapled from the delivery tray.
Pull out the staple case.
When the stapler unit is at the back and it is difficult to pull out the staple cartridge, turn the dial on the bottom left hand side to the left to move the stapler unit.
4.
Push up the bracket on the staple case.
5.
Remove all of the jammed and protruding staples from the staple cartridge.
6.
Return the bracket on the staple case to its original position.
7.
Gently push the staple case back into the stapler unit until it is securely in place.
Always make sure to insert the staple case far as it can go.
8.
Close the front cover of the finisher.
CAUTION
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
