Top » Problem Solving » Clearing Paper Jams » Paper Sources » Procedure to Remove the Jammed Paper Effectively from the Paper Drawers
08KE-0K3
If a paper jam occurs in the paper drawers and you do not perform correct operations, paper jam may occur continuously. This section explains how to clear the paper jam effectively in the paper drawers.
Do not apply (OK)
Apply (No Good (NG))
A paper jam occurs.
Check that there is a problem with paper.
Paper is loaded diagonally.
Paper appears dirty and has tears.
Several sheets of paper are attached.
Paper is already curled.
Step 3
Align the edges of paper and reload it.
Remove the paper with a problem.
→ Check that the machine operates normally.
Finish
Fan all four borders of paper well.
Finish
4.
Check that the paper stack is not curled.
Turn the paper stack over and check that the paper stack is not curled to the opposite direction.
Step 7
5.
Turn the paper stack over and reload it.
Finish
6.
Gently bend the paper in the direction opposite to the curl.
Reload the paper with less than ±1/5" (5 mm) curls.
Finish
7.
Use a new paper stack or change the paper type.
