Top » Problem Solving » Clearing Staple Jams (For Optional Products) » Stapler Unit of the Staple Finisher-N1/Booklet Finisher-N1
08KE-0KW
Check the location of the staple jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed staple.
Take care when handling the optional equipment that is attached to the machine. When an optional unit's cover is opened to replace a staple cartridge, discard the punch waste, discard the trim waste, discard the staple waste, or clear paper or staple jams, prints may still be output if other optional units are operating normally, and are not involved in the paper or staple jam removal procedure.
The Staple Finisher-N1 and Booklet Finisher-N1 are optional products.
Remove the paper waiting to be stapled from the delivery tray.
Open the front cover of the finisher.
Pull out the staple case.
4.
Push up the bracket on the staple case.
5.
Remove all of the jammed and protruding staples from the staple cartridge.
6.
Return the bracket on the staple case to its original position.
7.
Gently push the staple case back into the stapler unit until it is securely in place.
Always make sure to insert the staple case far as it can go.
8.
Close the front cover of the finisher.
CAUTION
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
