Take care when handling the optional equipment that is attached to the machine. When an optional unit's cover is opened to replace a staple cartridge, discard the punch waste, discard the trim waste, discard the staple waste, or clear paper or staple jams, prints may still be output if other optional units are operating normally, and are not involved in the paper or staple jam removal procedure.
Before clearing the staple jam, remove all output sheets from the booklet tray.
The Booklet Finisher-N1 is an optional product.
If a paper jam occurs at the same time as a staple jam, remove the jammed paper before removing the jammed staples.
Always make sure to push the saddle stitcher unit in as far as it can go.
When returning the saddle stitcher unit and closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
