Top » Problem Solving » Clearing Paper Jams » Booklet Finisher-N1 (Optional) » Inside the Front Cover
08KE-0KH
Follow the touch panel display, to remove the jammed paper.
The following illustration indicates the location of the paper jam. Please refer to it to remove the jammed paper.
*Front Cover
Open the front cover of the finisher.
Slide the guide (F-A1) to align it with the mark.
Slide the guide once to align  with  .
This procedure is not necessary only if the Puncher Unit-BF1 is attached.
Open the guide (F-B1).
4.
Remove any jammed paper.
1. Remove any jammed paper.
2. Close the guide (F-B1).
CAUTION
When closing the guide, be careful not to get your fingers caught, as this may result in personal injury.
5.
Open the guide (F-B2).
6.
2. Close the guide (F-B2).
CAUTION
7.
Turn the lower dial (F-B3) in the direction of the arrow (counterclockwise).
8.
Remove any jammed paper from the guide (F-B4).
1. Open the guide (F-B4).
2. Remove any jammed paper.
3. Close the guide (F-B4).
CAUTION
9.
Close the front cover of the finisher.
CAUTION
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
10.
Follow the instructions on the screen.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
