Top » Problem Solving » Clearing Paper Jams » Main Unit » Inside the Upper and Lower Right Covers
08KE-0JU
Check the location of the paper jam, and follow the procedure described below, and the procedure that appears on the touch panel display, to remove the jammed paper.
When the Paper Deck Unit-C1/POD Deck Lite-A1 is attached, move the Paper Deck Unit-C1/POD Deck Lite-A1 away from the main unit beforehand.
Remove any jammed paper from the upper right cover of the main unit.
1. Open the upper right cover.
2. Remove any jammed paper.
3. Close the upper right cover.
CAUTION
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
Remove any jammed paper from the lower right cover of the main unit.
1. Open the lower right cover.
3. Close the lower right cover.
CAUTION
When the Paper Deck Unit-C1/POD Deck Lite-A1 is attached, reconnect the Paper Deck Unit-C1/POD Deck Lite-A1 to the main unit.
Follow the instructions on the touch panel display.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
