Top » Problem Solving » Clearing Paper Jams » Booklet Finisher-N1 (Optional)
08KE-0KF
If a paper jam occurs inside the Booklet Finisher-N1, a screen prompting you to remove the jammed paper appears on the touch panel display. Follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
Take care when handling the optional equipment that is attached to the machine. When an optional unit's cover is opened to replace a staple cartridge, discard the punch waste, discard the trim waste, discard the staple waste, or clear paper or staple jams, prints may still be output if other optional units are operating normally, and are not involved in the paper or staple jam removal procedure.
The Booklet Finisher-N1 is an optional product.
