08KE-0JS
If a paper jam occurs in the main unit area, a screen prompting you to remove the jammed paper appears on the touch panel display. Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
The Paper Deck Unit-C1 and POD Deck Lite-A1 are the optional products.
