Top » Copy » Date Printing
Date Printing
0C1Y-0JF
This mode enables you to print the date on copies.
Press [Copy].
Press [Options] → [Print Date].
Set the image orientation and print position → press [Next].
The orientation types of originals are as follows:
[Portrait]:
Portrait refers to an original in vertical orientation:
the shorter edges are at the top and bottom of the original.
[Landscape]:
Landscape refers to an original in horizontal orientation:
the shorter edges are at the left and right of the original.
If you set any two of [Page Numbering], [Copy Set Numbering], or [Watermark] to print in the same position, a confirmation message appears when you press (Start).
4.
Specify the print settings for the date.
Select the size of the date from the <Size> drop-down list
Select the date format from the <Date Format> drop-down list.
Enter the desired date using - (numeric keys).
If no date is set, the date set in [Date/Time Settings] is printed. Confirm that the date and time settings are correct. (See "Current Date and Time.")
Press [Print Type].
Select the print type → press [OK].
If you select [Transparent], press [Light] or [Dark] to adjust the halftone density.
5.
Press [OK] → [Close].
Printing performance may not be optimal, depending on the original content and combination of settings.
