1
[Direct]
Press to make copies the same size as your original.
2
[Copy Ratio]
Press to specify the desired copy ratio.
3
[Select Paper]
Press to select the paper size/type and the paper source.
4
![]() You can specify the following settings:
Register/Edit Favorite Settings
Register to Quick Menu (See "Quick Menu.")
Change Default Settings
Register Options Shortcuts
5
[Check Settings]
Press to check, edit, or clear the current copy settings.
6
Shortcuts to [Options]
These are shortcuts to the [Options] modes. [Orig. Content Orientation], [2-Sided], [Density], [Original Type], and [Favorite Settings] are set as default. |
7
[Options]
Press to specify other settings. You can configure a range of copy functions.
8
[Interrupt]
The interrupt mode enables you to pause a reserved or current job to make higher priority copies.
1
[Favorite Settings]
Press to register frequently used copy settings. You can also recall registered settings. |
2
[Previous Settings]
Press to recall the three most recent copy settings. |
3
Press to specify the orientation of the original.
4
[2-Sided]
Press to specify the 2-Sided Settings. Press to make [1-Sided
5
[Original Type]
Press to select the type of original ([Text/Photo], [Printed Image], [Photo Printout], or [Text]) you are going to copy.
6
[Density]
Press to adjust the copy density.
7
[N on 1]
Press to automatically reduce two or four page originals to fit onto a one-sided or two-sided copy sheet. |
8
[Finishing]
Press to select the Collate, Group, or Staple mode. |
1
[Page Numbering]
This mode enables you to print page numbers. |
2
[Print Date]
This mode enables you to print the date. |
3
[Watermark]
This mode enables you to print a watermark. |
4
[Copy Set Numbering]
This mode enables you to print copy set numbers. |
5
[Secure Watermark]
Press to embed hidden text in the background of the print. The hidden text will become visible if the resulting output is copied. |
1
[Sharpness]
Press to sharpen or soften the original image on the copy. |
2
[Erase Frame]
Press to eliminate dark border areas, lines that appear around original images, or shadows from binding holes. |
3
[Shift]
Press to shift the position of the original image on the copy. |
4
[Copy ID Card]
Press to line up and copy both the front and back of a card onto a single sheet of paper. |
