Top » Copy » Appendix
Appendix
0C1Y-0JK
Relationship Between the Original Orientation and Paper Orientation
Use this appendix when stapling output printed on paper that is preprinted with a logo, etc.
When Stapling on the Right
When Stapling on the Left
When Not Stapling
If you are copying on the back side of a previously printed sheet, load the paper as indicated below.
Paper drawer: Load the side to copy on face up.
Multi-purpose tray: Load the side to copy on face down.
When setting the stapling location to one of the following, stapling is applied from the back sides of the printouts, and the claws of the staple appear on the front side (first page) of the printouts.
In horizontal (landscape) orientation, staple in the upper left
In horizontal (landscape) orientation, staple in the lower right
In vertical (portrait) orientation, staple in the lower left
In vertical (portrait) orientation, staple in the upper right
Other Settings
Example of Stapling Position
Top Right
LGL, LTR, EXEC
Top Right
LGL, LTR, EXEC
Bottom Right
LGL, LTR, EXEC
Bottom Right
LGL, LTR, EXEC
Preprinted paper
Loading location: Paper drawer
Preprinted paper: Face up
Loading location: Multi-purpose tray
Preprinted paper: Face down
Original
Loading location: Platen glass
Original: Face down
Stapling setting
Top Right
Top Right
Bottom Right
Bottom Right
Loading location: Feeder
Original: Face up
Other Settings
Top Left
LGL, LTR, EXEC
Top Left
LGL, LTR, EXEC
Bottom Left
LGL, LTR, EXEC
Bottom Left
LGL, LTR, EXEC
Preprinted paper
Original
Original: Face down
Stapling setting
Top Left
Top Left
Bottom Left
Bottom Left
Original: Face up
When Not Stapling
Other Settings
Example Output
LGL, LTR, STMT, EXEC
Preprinted paper
Original
Original: Face down
Original: Face up
Unavailable Combination of Functions
The following tables show the unavailable combinations of settings when you want to set more than one function at a time.
Function
Functions that Cannot Be Used in Combination
Preset Zoom
Zoom by Percentage*1, XY Independent*1, Auto Zoom*1, N on 1*1, Copy ID Card
Zoom by Percentage
Preset Zoom*1, XY Independent*1, Auto Zoom*1, N on 1*1, Copy ID Card
XY Independent
Preset Zoom*1, Zoom by Percentage*1, Auto Zoom*1, N on 1*1, Copy ID Card
Auto Zoom
Preset Zoom*1, Zoom by Percentage*1, XY Independent*1, Copy ID Card
Fit to Page
N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Page Numbering, Copy Set Numbering, Watermark, Print Date, Copy ID Card
*1 If you select these modes in combination, the mode which is set last has priority.
Function
Manual Paper Selection
Custom Size
Automatic Paper Selection(LTR/LGL)
Custom Size*1, N on 1*1, Erase Original Frame*1, Erase Book Frame*1, Erase Binding*1, Shift (By Position)*1, Shift (By Numeric Keys)*1, Copy ID Card*1
Custom Size
Manual Paper Selection, Automatic Paper Selection(LTR/LGL)*1, 1-Sided2-Sided, 2-Sided2-Sided, N on 1, Copy ID Card
Scanning Originals Loaded in the Feeder
Copy ID Card
Function
Collate
Group*1, Offset Collate*1, Offset Group*1, Staple*1, Copy ID Card
Group
Collate*1, Offset Collate*1, Offset Group*1, Staple*1, Copy Set Numbering, Secure Watermark*2, Copy ID Card
Offset Collate
Collate*1, Group*1, Offset Group*1, Staple*1, Copy ID Card
Offset Group
Collate*1, Group*1, Offset Collate*1, Copy Set Numbering, Secure Watermark*2, Copy ID Card
Staple
Collate*1, Group*1, Offset Collate, Copy ID Card
*2 You cannot combine these modes with Copy Set Numbering for Secure Watermark.
Function
1-Sided2-Sided
Custom Size, 2-Sided2-Sided*1, 2-Sided1-Sided*1, Copy ID Card
2-Sided2-Sided
Custom Size, 1-Sided2-Sided*1, 2-Sided1-Sided*1, Copy ID Card
2-Sided1-Sided
1-Sided2-Sided*1, 2-Sided2-Sided*1, Copy ID Card
N on 1
Automatic Paper Selection(LTR/LGL), Fit to Page, Custom Size, Erase Original Frame, Erase Book Frame, Shift (By Numeric Keys), Copy ID Card
Automatic Paper Selection(LTR/LGL), Fit to Page, N on 1, Erase Book Frame*1, Erase Binding*1, Page Numbering, Copy Set Numbering, Watermark, Print Date, Copy ID Card
Erase Book Frame
Automatic Paper Selection(LTR/LGL), Fit to Page, N on 1, Erase Original Frame*1, Erase Binding*1, Page Numbering, Copy Set Numbering, Watermark, Print Date, Copy ID Card
Erase Binding
Automatic Paper Selection(LTR/LGL), Fit to Page, Erase Original Frame*1, Erase Book Frame*1, Page Numbering, Copy Set Numbering, Watermark, Print Date, Copy ID Card
Interrupt
Copy ID Card
Function
Shift (By Position)
Automatic Paper Selection(LTR/LGL), Copy ID Card, Shift (By Numeric Keys)*1
Automatic Paper Selection(LTR/LGL), N on 1, Shift (By Position)*1, Page Numbering, Copy Set Numbering, Watermark, Print Date, Copy ID Card
Sharpness
Secure Watermark
Function
Page Numbering
Fit to Page, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Copy Set Numbering*3, Watermark*3, Print Date*3 Secure Watermark, Copy ID Card
Copy Set Numbering
Fit to Page, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Group, Offset Group, Page Numbering*3, Watermark*3, Print Date*3, Secure Watermark, Copy ID Card
Watermark
Fit to Page, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Page Numbering*3, Copy Set Numbering*3, Print Date*3, Secure Watermark, Copy ID Card
Print Date
Fit to Page, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Numeric Keys), Page Numbering*3, Copy Set Numbering*3, Watermark, Secure Watermark, Copy ID Card
Secure Watermark
Sharpness, Group*2, Offset Group*2, Page Numbering, Copy Set Numbering, Watermark, Print Date
Copy ID Card
Preset Zoom, Zoom by Percentage, XY Independent, Auto Zoom, Fit to Page, Automatic Paper Selection(LTR/LGL), Custom Size, Collate, Group, Offset Collate, Offset Group, Staple, Interrupt, 1sided2 sided, 2sided2sided, 2sided 1sided, N on 1, Erase Original Frame, Erase Book Frame, Erase Binding, Shift (By Position), Shift (By Numeric Keys), Page Numbering, Copy Set Numbering, Print Date, Watermark
*3 You can combine three modes at most among the following four modes: Page Numbering, Copy Set Numbering, Watermark, and Print Date.
Function
Background Density (Auto)
Background Density (Adjust)*1
Background Density (Auto)*1
