Original
Copy A
([Secure Watermark] Is Set to [Landscape])
Copy B
(Copy of Copy A)
Original
Copy C
([Secure Watermark] Is Set to [Portrait]) |
Copy D
(Copy of Copy C) |
[ID/User Name] is grayed out and cannot be selected if you are not using a login service.
Text that you enter in [Custom] is not automatically saved. When you are using [Secure Watermark], if you want to register your newly created secure watermark to be selected whenever necessary, press [Register] → enter the text to be registered.
(numeric keys).|
If no date is set, the date set in [Date/Time Settings] is printed. Confirm that the date and time settings are correct. (See "Current Date and Time.")
(numeric keys).
The [Adjust Background/Character Contrast] setting is canceled when the job is complete. If you want to use the same settings for the next copy job, specify the settings again.
The sample print includes the hidden text and the background for each relative contrast value.
The area within the frame on the sample print is the output sample for the currently set relative contrast value.
and
Standard Value Settings
Relative Contrast Value
1
0 to +7
4
-3 to +7
8 to 56
-7 to +7
60
-7 to +4
64
-7 to 0
The area within the frame on the sample print is the output sample for the currently set standard value.
and
to adjust the standard value → press [OK].|
You cannot change the copy density while copying with [Secure Watermark] set.
Printing performance may not be optimal, depending on the original content and combination of settings.
