Top » Copy » Selecting the Original Type
0C1Y-0J6
You can manually select the original type according to the type of image. The following original type modes are available.
Text/Photo Mode
Printed Image Mode
Photo Printout Mode
Text Mode
Text/Photo Mode
This mode is best suited for scanning originals containing both text and photos, such as magazines or catalogues.
Photo Mode
This mode is best suited for photos printed on photographic paper. If you set [Photo Printout Mode] to 'On', you can select the photo mode from [Photo Printout] and [Printed Image]. (See "Setting the Photo Printout Mode for the Copying Function.")
[Photo Printout]: This mode is best suited for images printed with halftone dots.
[Printed Image]: This mode is best suited for photos printed on photographic paper.
Text Mode
This mode is best suited for making copies of text originals. You can also copy blueprints or pencil drawn originals clearly using this mode.
Press [Copy].
Press [Options] → [Original Type].
Select the original type.
4.
Press [Close].
If you make copies of an original containing halftones, such as a printed photo, the moiré effect (a shimmering, wavy pattern) may occur. If this happens, you can soften the effect by using [Sharpness]. (See "Adjusting the Image Sharpness.")
If the original is a transparency, select the original type → adjust the exposure to the most appropriate level for the original.
