      0SU0-044
      Starting the Remote UI
      To operate remotely, you need to input the IP address of the machine into a Web browser and start the Remote UI. Check the IP address set to the machine in advance (Viewing Network Settings). If you are not sure, ask your Network Administrator.
      1
      Start the Web browser.
      2
      Enter "http://(the IP address of the machine)/" in the address field, and press the [ENTER] key on the keyboard.
      If you want to use an IPv6 address, enclose the IPv6 address with brackets (Example: http://[fe80::2e9e:fcff:fe4e:dbce]/).
      NOTE:
      If a security alert is displayed
      A security alert may be displayed when the Remote UI communication is encrypted (Enabling SSL Encrypted Communication for the Remote UI). When certificate settings or SSL settings have no errors, continue browsing the Remote UI.
      3
      Log on to the Remote UI.
      When Department ID Management is disabled
      Select [System Manager Mode] or [End-User Mode].
      You can perform all the Remote UI operations and configure all the settings. Enter the appropriate ID in [System Manager ID:] and PIN in [System Manager PIN:] (Setting the System Manager ID).
       [End-User Mode]
      You can check the status of documents or the machine, and you can also change some of the settings. If you wish to delete your print documents, enter the user name of the documents in [User Name:]. The user name is automatically set to print documents based on information such as your computer name or computer logon name.
      When Department ID Management is enabled
      Enter the appropriate ID in [Department ID:] and PIN in [PIN:] (Setting the Department ID Management).
      4
      Click [Log In].
      Portal Page (main page) is displayed. Remote UI Screens
