      0SU0-00H
      Logging on to the Machine
      When Department ID Management is enabled, you must log on before you can use the machine. When the logon screen is displayed, follow the procedure below to enter the Department ID and PIN. The logon process may also be required for the System Manager ID.
      1
      Enter your Department ID or the System Manager ID.
      1
      Use / to select <Dept. ID> (or <Manager ID>), and press .
      2
      Enter a number of up to seven digits using the numeric keys, and press .
      If no PIN is registered, proceed to step 3.
      2
      Enter the PIN.
      1
      Select <PIN>, and press .
      2
      3
      Press .
      The logon screen switches to the main screen.
      4
      When your operations are complete, press  to log out.
