You can check the list of setting items (
Setting Menu List) and current settings registered in the machine, such as paper size and type. You can also check the setting information for <Network Settings> and <System Management Settings> that are not included in the User Data List (
User Data List).
Example:
1
Press
2
Use
to select <Output Reports>, and press
3
Select <Print List>
<System Manager Data List>.
4
Check that the size and type of paper displayed on the screen is loaded in the machine, and press
5
Select <Yes>, and press
LINKS
