Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
Delivery Available |
[Auto Adjust Gradation]
Full Adjust : Start Printing key
No
No
Quick Adjust: Start key
Yes
No
Register Paper to Adjust: Paper to Adjust 1, Paper to Adjust 2, Paper to Adjust 3
No
No
Select Paper to Adjust: Paper Information List
No
No
Number of Sheets to Output for Test Page: 1 to 5 sheets of paper
1 sheet of paper
No
No
Initialize When Using Full Adjust: On, Off
Off
No
No
[Auto Correct Color Tone Settings]
[Auto Correct Color Tone]
Start Correcting, Change Corr. Pattern
No
No
[Register Correction Pattern]
Register Correction Pattern (adjusting value)
No
No
[Job Type to Apply To]
Copy: On, Off
Printer: On, Off |
Copy: On
Printer: On |
No
No
[Correct Density]
Copy/Scan and Store (Mail Box), Black & White Scan for Send, Color Scan for Send: 9 levels each
5 levels
No
No
[Correct Shading]
Densitometer Correction, Visual Correction, Print Server Correction
No
No
[Auto Correct Color Mismatch]
Start key
No
No
[Full Color Printing Vividness Settings]
Standard, Level 1, Level 2
Standard
No
No
[Fine Adjust Zoom]
X: -1.0% to +1.0%, in 0.1% increments
Y: -1.0% to +1.0%, in 0.1% increments
X: 0%
Y: 0%
No
No
[Dither Settings]
Gradation:
140-dot, 170-line, 170-dot, 190-dot, 210-dot, 230-dot Resolution: 140-dot, 170-line, 170-dot, 190-dot, 210-dot, 230-dot |
Gradation: 190-dot
Resolution: 230-dot |
No
No
[Color Balance]
Coated:
Yellow: -8 to +8
Magenta: -8 to +8
Cyan: -8 to +8
Black: -8 to +8
0
No
No
Fine Adjust Density: -8 to +8
High (Dark Area): 0
Medium: 0 Low (Light Area): 0 |
No
No
Non-Coated:
Yellow: -8 to +8
Magenta: -8 to +8
Cyan: -8 to +8
Black: -8 to +8
0
No
No
High (Dark Area): 0
No
No
[Correct Color Cast]
Yellow (-2-+2): - 2 to + 2
Magenta (-2-+2): - 2 to + 2 Cyan (-2-+2): - 2 to + 2 Black (-2-+2): - 2 to + 2 |
0
No
No
[Correct White Gap]
1 to 4
3
No
No
[Correct Uneven Gloss for 2-Sided Printing]
On, Off
Off
No
No
[Correct Tail End Toner Application]
On, Off
On
No
No
[Switch Fixing Temperature Adjustment Mode]
Productivity Priority (Auto), Productivity Priority (Manual), Image Quality Priority (Standard Gloss), Image Quality Priority (Low Gloss)
No
No
Productivity Priority (Manual): Thin Paper Priority, Standard, Heavy Paper Priority A, Heavy Paper Priority B
Standard
No
No
[Low Temperature Environment Mode]
0 to 4
0
No
No
[Correct Uneven Gloss]
0 to 4
0
No
No
[Adjust Drum Temperature]
Standard, High
Standard
No
No
[Special Smoothing]
On, Off
Off
No
No
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Saddle Stitch Staple Repositioning]*1
Start key
No
No
[Change Fold/Stitch Position]*1
-2.00 mm to +2.00 mm, in 0.25 mm increments
0.00 mm
No
No
[Adjust Saddle Stitch Fold Position]*1
0.00 mm
No
No
[Adjust Double Staple Width]*1
4 3/4" to 5 7/8"
4 3/4"
No
No
[Speed/Precision Priority for Double Staple]*1
Speed Priority, Precision Priority
Precision Priority
No
No
[Adjust Trim Width]*1
2.0 mm to 20.0 mm, in 0.1 mm increments
2.0 mm
No
No
[Fine Adjust Perfect Binding Finishing Size]*1
mm:
Horizontal: - 0.5 mm to + 0.5 mm, in 0.1mm increments
Vert. (Top+Bottom): - 1.0 mm to + 1.0 mm, in 0.1mm increments
No
No
Inch:
Horizontal: - 0.02" to + 0.02", in 0.01" increments
Vert. (Top+Bottom): - 0.04" to + 0.04", in 0.01" increments |
No
No
[Adjust Perfect Binding Glue Application]*1
Coated:
50 or Less: - 6 to + 6
51-100: - 6 to + 6
101-150: - 6 to + 6
151 or More: - 6 to + 6
0
No
No
Non-Coated:
51-100: - 6 to + 6
101-150: - 6 to + 6
0
No
No
[Adjust Fold Position]*1
[Adjust Z-Fold Position]
-2.0 mm to +1.5 mm, 0.5 increments
0.0 mm
No
No
[Adjust C-Fold Position]
When the Paper Folding Unit-J1 is attached:
-7.0 mm to +5.0 mm, in 0.5 mm increments
-1.0 mm
No
No
[Adjust Accordion Z-Fold Position]
-7.0 mm to +5.0 mm, 0.5 increments
-1.0 mm
No
No
[Adjust Double Parallel Fold Position]
A: -2.0 mm to +5.0 mm, 0.5 increments
B: 0.0 mm to +5.0 mm, 0.5 mm increments |
A: -1.0 mm
B: 1.0 mm |
No
No
[Adjust Half Fold Position]
-2.0 mm to +2.0 mm, 0.5 increments
0.0 mm
No
No
[Adjust Saddle Fold Position]
When the Saddle Finisher-AN2 is attached:
-8.50 mm to +8.50, 0.25 increments |
0.00 mm
No
No
[Correct Curl for Each Paper Drawer]
Face Up Output (Reverse): -10 to +10
Face Down Output (Normal): -10 to +10 |
0
No
No
[Alignment Adjustment When Stapling]*1
- 3.0 mm to + 3.0 mm, in 0.1 mm increments
0.0 mm
No
No
[Finisher Tray A Alignment Adjustment]*1
0.0 mm
No
No
[Finisher Tray B Alignment Adjustment]*1
0.0 mm
No
No
[Finisher Output Priority Settings (Thin)]*1
Productivity Priority, Alignment Priority
No
No
[Switch Saddle Fold Mode]
Alignment Priority
No
No
*1
Indicates items that appear only when the appropriate optional equipment is available for use.
Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
[Clean Inside Main Unit]
Start key
No
No
[Clean Feeder]*1
Start key
No
No
[Clean Wire]
Start key
No
No
[Clean Roller]
Start key
No
No
[Original Scanning Area Cleaning Method]*1
Displaying cleaning method
No
No
[Refresh Fixing Roller]
Start key
No
No
[Fixing Roller Auto Refresh Level]
Level: - 5 to + 5
0
No
No
[Initialize After Puncher Unit Die Lubrication]
Yes, No
No
No
[Initialize After Replacing Parts]
[Primary Cleaning Web Unit]
Yes, No
No
No
[Secondary Cleaning Web Unit]
Yes, No
No
No
*1
