Paper Alignment on Finisher Tray A/B
You can adjust paper alignment when outputting on Tray A or B of a finisher.
This mode can be set when the Finisher-AN1 or Saddle Finisher-AN2 is attached.
(See "Finisher-AN1/Saddle Finisher-AN2/Puncher Unit-BS1/Puncher Unit-BT1.")
You cannot align output paper in the following situations:
when using paper smaller than STMTR
when using different size paper together
If you set [Align Output Paper of Diff. Sizes (Diff. Width)] to 'On', you can align output paper by paper width. (See "Aligning Output Paper of Different Width.")
Press
(Settings/Registration).
Press [Adjustment/Maintenance] → [Adjust Action] → [Finisher Tray A Alignment Adjustment] or [Finisher Tray B Alignment Adjustment].
Press [-] or [+] to adjust the paper alignment → [OK].
You can switch between positive and negative values by pressing [±].
