Making the Color More Vivid When Printing with Full Color
You can set the color to be more vivid when copying/printing stored files. You can set a default value for all jobs, rather than setting the color for each job separately.
This mode is enabled if you select [Full Color] in [Select Color] for the Copy or Access Stored Files function, or if the machine detects that the original is in full color when [Auto (Color/B&W)] is selected.
[Adjustment/Maintenance] → [Adjust Image Quality] → [Full Color Printing Vividness Settings].
Select [Level 1] or [Level 2] → press [OK].
[Level 2] uses color more vivid than [Level 1].
Press [Standard] to reproduce the colors of the original.
This setting is enabled only after you restart the machine (the main power switch is turned OFF, and then back ON). For information on how to turn ON and OFF the main power of the machine, see "Before You Start Using This Machine."
» Adjustment for Image Quality and Finishing (Calibration) » Adjust Image Quality » Making the Color More Vivid When Printing with Full Color
0S9Y-06R
