This function is displayed only if the settings are made available by your local authorized Canon dealer. Even if this function is displayed, do not allow anyone to change the settings except for the system manager. For more information on changing the settings, contact your local authorized Canon dealer.
Adjusting this function may cause paper jams or poor image quality depending on the paper type.
Adjusting this function may affect the paper curl. Readjust [<Curl Correction Level>] if necessary. (See "Curl Correction for Each Paper Deck.")
(Settings/Registration).|
[Productivity Priority (Auto)]:
This mode is the default setting.
Suitable temperature for the fixing unit will be applied. This mode gives a priority to productivity, so the gloss quality may be slightly changed. |
[Productivity Priority (Manual)]:
Suitable temperature for the fixing unit will be applied by setting the frequently-used paper type beforehand.
The mode gives a priority to productivity, so the gloss may be slightly changed. Select this mode to prioritize productivity from the very first page. |
[Image Quality Priority (Standard Gloss)]:
This mode gives a priority to image quality, so productivity may be slightly affected.
[Image Quality Priority (Low Gloss)]:
This is a fixed temperature adjustment mode that prioritizes image quality. The gloss may differ slightly from the Image Quality Priority (Standard Gloss) mode.
Frequently Used Paper Type
Item
Uncoated paper (16 to 67lb.(60 to 180 g/m2)) & Coated paper (21 to 67lb.(80 to 180 g/m2))
[Thin Paper Priority]
Uncoated paper (16 to 111lb.(60 to 300 g/m2)) & Coated paper (28 to 95lb.(106 to 256 g/m2))
[Standard]
Uncoated paper (34 to 130lb.(129 to 350 g/m2)) & Coated paper (34 to 95lb.(129 to 256 g/m2))
[Heavy Paper Priority A]
Uncoated paper (34 to 130lb.(129 to 350 g/m2)) & Coated paper (34 to 130lb.(129 to 350 g/m2))
[Heavy Paper Priority B]
If gloss cannot be permitted for a specific type of paper when [Productivity Priority (Manual)] is selected and the most frequently used paper type is set, adjust the gloss on that paper. (See "Adjusting the Gloss and Fine Black.")
If gloss cannot be permitted for most types of paper when [Productivity Priority (Manual)] is selected and the frequently used paper type is set, change to the [Quality Priority] mode.
If gloss cannot be permitted on most types of paper after changing to the [Quality Priority] mode, adjust the gloss of the specific type of paper being used. (See "Adjusting the Gloss and Fine Black.")
