Make sure to perform this function in the stable room environment (i.e. temperature and humidity). The color may become unstable due to the rapid changes in room environment, especially soon after staring up an air conditioner during summer or winter season.
It is recommended that you select [Full Adjust] when performing an automatic gradation adjustment. Select [Quick Adjust] for a quick, but less complete adjustment between regular full adjustment recalibrations.
This machine adjusts the toner and print speed according to the paper type. To make effective adjustments, select the correct paper type.
Test pages are not counted as part of the copy or print total page counts.
Confirm that the following size and type of paper is set in the paper source before starting this procedure.
* The name of the paper is subject to change without notice. For more information, contact your local authorized Canon dealer.
To improve the precision of the full adjustment, press [Number of Sheets to Output for Test Page] and increase the number of sheets to output for test page. The following table shows the relationship between the setting value and actual number of sheets to output for test page. To perform this procedure, you must log in to the machine as an administrator. (See "Logging In to the Machine as an Administrator.")
(Settings/Registration).
(Settings/Registration).|
Make sure to register paper to adjust in the stable room environment (i.e. temperature and humidity).
If the rapid changes in room environment occur after the registration of paper to adjust, accurate recalibrations of the gradation, density, and color settings of the machine cannot be made for paper already registered to adjust. In this case, register again that paper to adjust.
When registering paper to be adjusted, it is recommended to register paper with a finish and whiteness equivalent to the Hammermill Color Copy Digital (28lb. (105 g/m2)). Accurate recalibrations of the gradation, density, and color settings of the machine may not be made if you register and use paper other than that condition as paper to adjust.
To perform the procedure described in this section, you must log in to the machine as an administrator. (See "Logging In to the Machine as an Administrator.")
Confirm that both paper to use as a basis and a custom paper type to register to adjust, described in the following table, are set in paper sources correctly before starting this procedure.
While you are registering the custom paper type as a paper to adjust, the paper type settings are protected and you cannot change the detailed information for custom type or delete the custom type in [Paper Type Management Settings] in [Preferences] (Settings/Registration).
You can register up to three type of paper to adjust and you can overwrite them. When overwriting, you cannot restore the paper settings previously registered.
(Settings/Registration). |
To perform the auto gradation adjustment to some custom paper type, select that custom paper type, which is registered in advance, for paper to adjust.
