Use 12" x 18", 12 5/8" x 17 11/16", 11" x 17", LGL, LTRR, or custom size (8 1/4" x 11" to 12 5/8" x 18" (210 mm x 279.4 mm to 320 mm x 457 mm)) paper for the saddle stitch staple repositioning procedure.
Make sure to remove all output booklets from the Booklet Tray of the finisher or the stack area of the trimmer before performing the saddle stitch staple repositioning procedure.
This mode cannot be performed if transparency/clear/translucent film can be fed. Open the paper drawer or paper deck which contains transparency/clear/translucent film, keep it open so that transparency/clear/translucent film cannot be fed, and then perform this mode.
(Settings/Registration).|
Paper that is required for the saddle stitch staple repositioning procedure is automatically fed to the saddle stitcher unit by the machine.
