(Settings/Registration).|
[Productivity Priority]
This mode gives a priority to productivity. The output paper may not be aligned.
[Alignment Priority]
As a priority is given to aligning the output paper, the production speed decreases compared with [Productivity Priority] mode.
[<Switch Saddle Fold Mode>] is enabled when using the following paper.
Paper type: Thin paper, plane paper, heavy paper, coated paper
Basis weight: Thin paper: (16 to 21lb.(60 to 79 g/m2)), plane paper: (21 to 28lb.(80 to 105 g/m2)), heavy paper: (28 to 77lb.(106 to 209 g/m2)), coated paper: (28 to 77lb.(106 to 209 g/m2))
When [<Productivity Priority>] is selected, the edges of the saddle fold may not be aligned due to the temperature, humidity, paper characteristics or image density.
