e-ManualTopSite mapHelp
Category Top
Loading Paper
Loading Paper into a Paper Deck (Main Unit, POD Deck-D1 (Optional))
Adjusting a Paper Deck to Hold a Different Paper Size (Main Unit, POD Deck-D1 (Optional))
Loading Pre-Punched Paper
Loading Transparency/Clear/Translucent Film
Loading Tab Paper
Loading Paper into the POD Deck Lite-C1 (Optional)
Loading Paper into the LONG SHEET TRAY-A1 (Optional)
Loading Paper into the Document Insertion Unit-N1 (Optional)
Replacing the Staple Cartridge (For Optional Products)
Replacing the Staple Cartridge in the Stapler Unit (Finisher-AN1/Saddle Finisher-AN2)
Replacing the Staple Cartridge in the Saddle Stitcher Unit (Saddle Finisher-AN2)
Removing Staple Waste (Finisher-AN1/Saddle Finisher-AN2)
Removing Punch Waste (Puncher Unit-BS1/Puncher Unit-BT1)
Operating the Limited Functions Mode
Replacing Cleaning Web Unit
Replacing the Toner Cartridge
Replacing the Waste Toner Container
Routine Cleaning
Originals Cannot Be Scanned Properly (Cleaning the Platen Glass)
Originals Cannot Be Scanned Properly (Cleaning Method of the Original Scanning Area)
Scanned Originals Become Dirty (Manual Feeder Cleaning)
Scanned Originals Become Dirty (Automatic Feeder Cleaning)
Output Paper Becomes Dirty (Cleaning Inside of the Main Unit)
Output Paper Becomes Dirty (Wire Cleaning)
Output Paper Becomes Dirty (Roller Cleaning)
Streaks and Gloss Unevenness Appear on Output Paper (Refreshing the Fixing Roller)
Streaks and Gloss Unevenness Appear on Output Paper (Adjusting the Fixing Roller Auto Refresh Level)
Cleaning the Touch Panel Display
Consumables
Top » Maintenance » Routine Cleaning » Scanned Originals Become Dirty (Manual Feeder Cleaning)
0S9Y-08X
If originals that have been fed through the feeder have streaks or appear dirty, clean the feeder's scanning area.
Clean the feeder's scanning area with a cloth which is wrung after being dampened in water, and then wipe them clean with a soft, dry cloth.
The location of the Duplex Color Image Reader Unit-K1 is indicated in the following illustration.
If the document feed scanning area is dirty, documents may not be scanned clearly, and the size of the document may not be detected correctly.
This procedure is necessary only if the Duplex Color Image Reader Unit-K1 is attached.
Clean the original scanning area (thin glass strip).
1. Open the feeder.
2. Clean the original scanning area.
Use the glass cleaning cloth provided as a machine accessory of the Duplex Color Image Reader Unit-K1 when simple cleaning.
When glass cleaning cloth becomes dirty, wash and rinse, and then spread it out to dry.
Open the covers.
1. Pull the lever above the feeder, and open the document scan cover.
2. Open the inside cover.
Open the document scan cover carefully, as not to scratch the platen glass.
Clean the feed scanning area (thin glass strip).
4.
Close the covers and the feeder.
1. Close the inside cover.
2. Close the document scan cover.
3. Close the feeder.
CAUTION
When closing the covers and the feeder, be careful not to get your fingers caught, as this may result in personal injury.
Be aware that the light emitted from the platen glass may be very bright when closing the feeder.
