Call your service representative before you operate the module separation switch.
Cause:
The Puncher Unit-BS1 or Puncher Unit-BT1 is out of order.
Remedy:
You can make copies/prints using functions other than the hole punch function by operating the Limited Functions Mode.
Cause:
The Finisher-AN1 or Saddle Finisher-AN2 is out of order.
Remedy:
You can only output copies/prints by operating the Limited Functions Mode to restrict all of the functions for the finisher such as staple and collate.
Cause:
The saddle stitcher unit of the Saddle Finisher-AN2 or the Booklet Trimmer-D1 is out of order.
Remedy:
You can make copies/prints using functions other than the saddle stitch function by operating the Limited Functions Mode.
Cause:
The Paper Folding Unit-J1 is out of order.
Remedy:
You can make copies/prints without using the folding mode by operating the Limited Functions Mode.
Cause:
The Perfect Binder-E1 is out of order.
Remedy:
You can make copies/prints using functions other than the Perfect Binding mode by operating the Limited Functions Mode.
After setting the Limited Functions Mode to 'On', the corresponding function will be grayed out on the display, and cannot be used.
(Settings/Registration).|
For instructions on setting the Limited Functions Mode from the Service Call Message screen, see "Setting the Limited Functions Mode from the Service Call Message Screen."
The Limited Functions Mode is enabled only after you restart the machine (the main power is turned OFF, and then back ON). For instructions on restarting (turning the main power OFF, and then back ON) the machine, see "Main Power and Energy Saver Key."
