Make sure to perform this function in the stable room environment (i.e. temperature and humidity). The color may become unstable due to the rapid changes in room environment, especially soon after staring up an air conditioner during summer or winter season.
It is recommended that you select [Full Adjust] when performing an automatic gradation adjustment. Select [Quick Adjust] for a quick, but less complete adjustment between regular full adjustment recalibrations.
This machine adjusts the toner and print speed according to the paper type. To make effective adjustments, select the correct paper type.
Test pages are not counted as part of the copy or print total page counts.
[Perform Auto Adjust Gradation (Full Adjust)] and [Perform Auto Adjust Gradation (Full Adjust) + Auto Correct Color Tone] cannot be selected in the event of color sensor failure.
Press this button to perform a full gradation adjustment and auto color tone correction on the same paper. The printer executes an auto color tone correction followed by a full gradation adjustment. This achieves high operability and reduces the time required for the corrections as the adjustments are automatically performed successively.
