e-ManualTopSite mapHelp
Top » Problem Solving » Clearing Staple Jams (For Optional Products) » Saddle Stitcher Unit of the Saddle Finisher-AM2
0L3X-0SS
This section describes how to clear a staple jam which occurs in the saddle stitcher unit of the Saddle Finisher-AM2. The location of the Saddle Finisher-AM2 is indicated in the following illustration.
Take care when handling the optional equipment that is attached to the machine. When an optional unit's cover is opened to replace a staple cartridge, discard the punch waste, discard the trim waste, discard the staple waste, or clear paper or staple jams, prints may still be output if other optional units are operating normally, and are not involved in the paper or staple jam removal procedure.
Before clearing the staple jam, remove all output sheets from the booklet tray.
The Saddle Finisher-AM2 is an optional product.
If a paper jam occurs at the same time as a staple jam, remove the jammed paper before removing the jammed staples.
Follow the procedure described below, while referring to the location of the staple jam and the directions that appear on the touch panel display, to remove the jammed staples.
Open the front cover of the finisher.
Pull out the staple case from the saddle stitcher unit (F-C4).
1. Pull out the saddle stitcher unit (F-C4).
2. Pull out the staple case.
Hold the staple case by its left and right sides, and lower the bracket on the staple case.
4.
Remove all of the jammed and protruding staples from the staple cartridge.
5.
Return the bracket on the staple case to its original position.
6.
Return the staple case to its original position in the saddle stitcher unit.
When returning the staple case, always make sure to the staple case is inserted until the arrows are aligned as shown in the diagram.
7.
Push the saddle stitcher unit (F-C4) back into the machine, and close the front cover of the finisher.
1. Gently push the saddle stitcher unit (F-C4) back into the machine.
Always make sure to push the saddle stitcher unit in as far as it can go.
2. Close the front cover of the finisher.
CAUTION
When returning the saddle stitcher unit and closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
When you have cleared the staple jam, be sure to manually reposition the staples in the saddle stitcher unit. (See "Saddle Stitch Staple Repositioning.")
