Main Unit
If a paper jam occurs in the main unit area, a screen prompting you to remove the jammed paper appears on the touch panel display. Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed paper.
The Multi-drawer Paper Deck-B1, POD Deck Lite-B1, and Output Tray-A1 are the optional products.
» Problem Solving » Clearing Paper Jams » Main Unit
0L3X-0RJ
