Left Part of the Machine
This section describes how to clear a paper jam which occurs in the left part of the machine. The location of the left part of the machine is indicated in the following illustration.
If the Output Tray-A1 is attached to the main unit, remove all output paper from the tray. It may be necessary to lift the Output Tray-A1 up, depending on the paper jam.
The following illustration indicates the location of the paper jam. Please refer to it to remove the jammed paper.
* Front Left Cover
Follow the procedure described below, while referring to the location of the paper jam and the directions that appear on the touch panel display, to remove the jammed paper.
Close the cover that is open.
CAUTION
When closing the cover, be careful not to get your fingers caught, as this may result in personal injury.
Open the left cover on the front side of the main unit.
Open the guide (C-B1) and guide (C-B2), and turn the knob (C-B3) to move any jammed paper.
1. Open the guide (C-B1).
2. Open the guide (C-B2).
3. Turn the knob (C-B3) to move any jammed paper.
Turn the knob (C-B3) in the counter-clockwise direction to feed the jammed paper to the guide (C-B1).
Turn the knob (C-B3) in the clockwise direction to feed the jammed paper to the guide (C-B2).
4.
Remove any jammed paper.
When feeding any jammed paper to the guide (C-B2)
When feeding any jammed paper to the guide (C-B1)
5.
Remove any jammed paper from the left cover (C-B4) of the main unit.
1. Open the left cover (C-B4).
2. Remove any jammed paper.
3. Close the left cover (C-B4).
CAUTION
6.
Close the guide (C-B1) and guide (C-B2).
1. Close the guide (C-B2).
2. Close the guide (C-B1).
7.
Close the left cover on the front side.
CAUTION
8.
Follow the instructions on the screen.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
» Problem Solving » Clearing Paper Jams » Main Unit » Left Part of the Machine
0L3X-0RR
